Quick Record, When Assigned to a Function Key, Doesn't Light the Key When Active
NICE that you can assign "Quick Record" and "Quick Playback" to one of the programmable Function Keys. Super helpful when trying to setup your mic profiles.
BUT, like the title says: When either Quick Record or Quick Playback is assigned to an Fx key, and the key is pressed, the key doesn't light to indicate that the function is active. This makes is harder than it should be to use these functions, given that there's no indication on the Maestro's default screen that (for example) Quick Record is in progress. Yes, I realize that I can touch the frequency and see it there.
The Fx button behavior for Quick Record/Playback is UNlike assigning, say, NR to one of the Fx keys: When you press the key, engaging NR, the key lights. You press it again, the light goes out.
OK, Flex-folks. Is there something specific I need to do to get a bug filed for this? I kinda just expected somebody to see this and reply with a case number or something similar. It does look like a clear bug to me. Easy to repro at will.
Hi Peter, submit a help desk ticket.
Ah! Sorry. Didn't realize that was the protocol.
Thank you. Done!
- 696 The Flea Market
- 121 Aurora
- 983 Genius Products
