Tuner Genius - How Many Tuned Memories When Paired With Antenna Genius?
N3PS
N3PS Member ✭✭
The most current literature indicates that Tuner Genius can memorize 20 tuner solutions per band (11 bands x 20 = 220 solutions). If the Tuner Genius is paired to an 8x1 Antenna Genius, how many solutions would be memorized? Just 220 or up to 1,760 (11 x 20 x 8)?
  • David Decoons, wo2x
    20 per band per antenna, up to four antennas per band.
    That was the last spec I heard.
  • N3PS
    N3PS Member ✭✭
    I reached out to Flex Radio who reached out to 4O3A:
    "There are 20 memories per band, and there are 9 antenna slots available per band when paired with AG.
    In total, there are 20 x 12 x 9 memory slots in TGXL memory = 2160"
  • JohnEin
    JohnEin Member ✭✭
    If all the memory slots for a given band (e.g., 30m that is only 50KHz wide) are not used are these memory slots available for another band (e.g., 6m that is 4MHz wide)?
    No,
    There are 20 memories per band per antenna when used with the AG. And only up to 4 antennas per band.
    How many people have more than 4 antennas per band? I am not talking about antennas they can tune on a band but actual antennas you would actually use on a band? Here I have one antenna per band so simple to have auto antenna selection.
