New Failure Message
Hi, I receive a new failure message on 6400M screen "OneDriveSetup.exe - Entry Point Not Found". The procedure entry point GetUserDefaultGeoName could not be located in the dynamic link lybrary. And than the Path C:\Usere and so on.
Does somebody knew whats wrong?
Thganks for help - Detlef / DK6OR
Many thanks for your answers. I will continue pressing the OK Button in the OneDrive Icon as long as necessary. HI.
Best Regards
Detlef - DK6OR
Flex are aware of this and they are looking in to it, something Microsoft related.
Seen message from them elsewhere you should just be able to click ok and continue using it as normal.
Its like the plague, it keeps coming back every so often.
Why would one drive be in my radio?? Is flex collecting our info.
One Drive isn't in your radio. But, it is, or has been, a part of Windows 10 and 11 for quite a while. Your M model radio's front panel or Maestro, uses an Enterprise version of Windows. Flex Radio has in the past been able to block forced updates to Windows in those two devices. Windows Update looks at your system when Microsoft pushes an update to see if anything is missing or out of date. If anything is out of date or missing, then, Windows Update will send the update to your device. For whatever reason, Flex Radio is not able to block update notifications for some things. And that is why you keep getting the pop-up. One Drive isn't being installed by Windows Update, and that's why the error message continues to show up.
Hopefully, Flex Radio will find a solution to this annoying problem.
- 692 The Flea Market
