Assigning bands to port A or port B
I am running a Flex 6600, TGXL, and PGXL. If I connect a hexbeam (6-20) to Port A and a fan dipole (40-160) to Port B, can SmartSDR be configured to select the correct antenna when I choose a certain band? Sort of like the AG does, except with only two antennas and no AG?
You can do this with profiles but I find it easier just using a third party tool called Flex Buttons. It's free and works great for sending commands to the flex for changing settings etc.
With this you can create a button which sets the band, frequency, tx antenna, rx antenna etc.
So you could set up a button per hand which has all the info stored for your set-up/
Smart SDR will always remember the antenna port last used for a band, regardless of what slice you are on. Using the buttons forces the right settings every time.
Rich
Thanks! That is just what I was looking for.
