no audio from radio sport headset through smartsdr.
tgiro01
tgiro01 Member ✭✭
I'm using a Radio Sport headset connected to my PC. When I run a windows test, I'm getting audio from the mike into the PC. But SmartSDR doesn't respond. No microphone audio is going through to the radio. I'm missing something, but don't know what. Here is what I'm seeing in Smart SDR.
Does anyone spot what I'm missing or what I should check? This is happening on my laptop, also with a Heil Pro headset on it. The PC is running Windows 10 and the laptop Windows 11, but I'm pretty sure I'm missing a setting in SmartSDR.
Thanks for any help.
BTW - the radio is connected to a dummy load for transmit testing.
    I think you need to change from mic to pc and turn off DAX (all on the control panel).
  • tgiro01
    tgiro01 Member ✭✭
    That Works!
    It can't be that easy. Thank You. What I get from reading to much into the manuals.
