WSJT-X (FT-8) and JT Alert
Is there a good you tube video on how to setup WSJT-X and FT-8 and JT Alert ?
Thank you.
  • Rick_KJ5WO
    Rick_KJ5WO Member ✭✭
    edited January 2024
    Hi James, I had good luck just down loading WSJT-X and installing it. Then download and install SliceMaster and run it. It will see and configure WSJT-X for you. I couldn't be simpler. It might work with JT Alert as well. Here is a link to Mike's YT video too. Make sure you have DAX setup on at least one slice for Slice Master to find.
    Good luck. Rick...
