Trying integrate N1MM for RTTY contest this weekend ERROR
Jeff VK5IU
I get the following error "Cannot open 'COM11" at 45 baud; if the selected serial port can't handle this baud rate, use EXTFSK"
What does this all mean. Trying to setup N1MM and MMTTY for the contest with very good video from Flex.
You cannot use FSK with the Flex - it must be AFSK. No COM port is needed. Transmit is audio stream via DAX.
73, Craig KØCF
I thought that maybe the answer. Just that it is a little bit daunting trying to set up N1MM and Flex for the RTTY contest this weekend. Thanks Craig for your speedy help.
- 696 The Flea Market
- 121 Aurora
