PTT when using USB microphone for PC voice into Flex transmit
If the radio’s PTT port is convenient, why not use the radio’s mic jack?
I use an XLR mic, with a Distribution Amp to several radios. In this case, the mic doesn't have PTT, and even if it did, I would have to switch it among the radios. So my solution is to have separate PTT solutions for each radio. This may work for you in your case.
I can understand if your USB mic includes a PTT switch - I'd want that to work in the "expected manner" also.
Among my various PTT devices: footswitches, and hand-switches. I tried the SmartSDR MOX button and that was going to drive me InSaNe !
Summary: While I agree with your desire to have PTT recognizable from USB port, the reality may require a PTT switch workaround. Fortunately, my FlexRadio 6400 (and quite like your model also) includes an easy-to-use PTT input.
@k4rgn , there is another way, but it involves a USB to RS232 adapter and a switch.
Set up a PTT port in SmartSDR CAT (click the Add... button)
Give it a name that is meaningful to you. It will pick an open serial port (mine happens to be COM16). At the RS232 end, put a switch from RTS to ground. Now you have a PTT button or footswitch that will work regardless of the source of audio.
This solution does not speak to your assertion that the rig should always be able to key from the back panel, but it does provide a work-around if you really need it.
Hey Ken!
I'm looking at using this to trigger PTT via software. Am I correct in my assumption that I can connect a serial object (like .NET's SerialPort class) and **** with RTS/DTR programmatically?
Not sure what else "PTT" as "Port Protocol" means.
HNY and thanks for all you do!
-Brian n8wrl
Hi Brian, I suppose that might work but if you are going to do it programatically, I would suggest the Flex API. There are a couple of routes that you can take.
One is Node Red. Dave, WO2X and Alan WA9WUD have laid a lot of the groundwork to make that pretty easy.
Another is C# and .net with the FlexLib library. I have some sample code on GitHub that will get you started if you choose this route.
Finally, you can use your language of choice and use the API natively. It is text based and pretty straightforward to use. The other solutions take care of discovery and that kind of thing so that you don't have to reinvent that particular wheel.
PTT in the port protocol box just means that CAT will interpret a switch closure (RTS or DTR) as PTT and send the appropriate API command to the rig.
Good luck with your project!
This is a very reasonable request. Not being able to use a footswitch to key the mic when using PC audio is a miss of basic functionality. The PC audio is already routed in, the PTT is already there. Need a simple selector, or simply let the PTT on the back of the radio key whatever is selected as the audio source.
Certainly shouldn't need a workaround with external software, etc. for this functionality. Thank you!
Coming back to this one in 2025 (nearly 2026)
I would love to see Flex revisit this, especially in their new age of more rapid software development. Simply: Allow the physical RCA PTT to key the radio and pass audio from the PC (if that’s the source selected in the MIC menu)
I find myself needing to turn on my Maestro in Smart Control mode—when I don’t need/want it—purely to pass the physical PTT of my foot switch onto the radio.
Background: Flex 8600. 4.13 software with the extended license. Use PC default mic which is an Oktava MK-012 pencil mic on a boom running into an SSL USB audio interface. Have a lovely fooswitch that won’t directly key the radio with this setup. :)
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
