problem with remote tx audio
When I operate remotely using Smartlink I have no problems. If I try to use Chrome Remote Desktop everything work fine except I cannot get any tx audio. I keep getting a warning of the wrong or no PC input device. When selecting PC for mic it is flagged not connected. When trying to select a microphone either at the remote site or locally only Dax audio is available. All in windows 10.
Any ideas?
I think, it might be similar to remoting powersdr via remote desktop tools.
You must have virtual audio cable to connect the incoming audio to the smartsdr audio input somehow.
Hence..there is no reason for remoting a desktop for the flex6000.. you can use smartlink and if you really need the system when smartlink is out of order .. you can set up a layer2 VPN ( mostly softethernet )
Some users are remoting to see the GUI and connect with RCFORB ( remotehams ) for tuning and audio
Harry
I am using Smartlink and it works very well. I would also like to use Chrome Remote Desktop. I want to have full control over my 6600 remotely for total operation of it and possible updating it. I just can't get the transmit audio to work, all other functions work as they should.
- 398 Community Topics
- 678 The Flea Market
- 192 SmartSDR+
- 392 SmartSDR API
- 96 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
