serious trouble during actual contest
73 Manfred
Hi Manfred... sorry to hear about your difficulties, but that red blinking light is usually a sign that there is something significantly wrong inside the radio -- wrong enough that it pretty much REQUIRES opening a Help Desk ticket. Repeatedly resetting the radio to 'make it go away' was probably just hiding the underlying issue.
The staff @ Flex have always been very responsive and helpful when I've had troubles and got their Help Desk involved.
From the sounds of your symptoms (I'm no expert) it sounds like something within the radio's internal database has become corrupted. Again, a job for the Help Desk to determine. It could be as simple as a new SD card, but I'm just guessing.....
About the only thing external to the radio that can cause a red led is the power source or connectors. Try reseating the power connector on the radio or a different power supply. It could also be the fuse/fuse socket inside of the radio. But do not hesitate to open a help desk ticket if that does not solve the problem.
AL, K0VM
Hi Manfred, I would submit a help desk ticket right away.
Flex CAN fix many things on the 6300 radio's STILL and you just need to send it in and have them see if they still have parts, My very good friend just got his 6300 back from a complete failure and they was able to repair it at a reasonable cost.
As far as the 6400 goes If it's a M version you could pop the cover and exercise the Internal Ethernet cables between the Front face and the rest of the body, they are just short Ethernet Cables.
I had a 6600M that all it took was to exercise the cables so it may be worth a try.
It may be a bad SDcard so a help ticket will be required to get a replacement.
- 694 The Flea Market
