IOS Audio-MIC Settings question
Hello can anyone tell me a good setting for my mic input when using the IPAD PRO built in mic ? Yesterday I noticed my mic was set to hot and I was over modulating.
Thank you
James: I noticed the same and reduced the Mic volume adjustment setting to around -.8 or so. Apparently the mic audio is relatively ‘hot’. Same procedure as any other mic and as described in the SSDR manuals. Watch the slider. Without the adjustment the compression was also WAY up. But backing off the mic audio brought everything into tolerance.
I use Mic Volume -4 and Threshold 0.1 when using the iPhone as a Speaker Phone. Otherwise audio too hot. I forget what i use for AirPods but it is different. dan WA1QZx
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
