N1MM+ SEND CW WINDOW HANGS FLEX 6300 IN XMT AFTER TEXT COMPLETES
Martin Blustine
When I use the N1MM+ CW Window, the Flex hangs in transmit mode with transmit bias enabled until I hit the ESC key, or CNTRL K once again.
Why does PTT remain enabled once the text has completed?
Is there a way around this? Why doesn't the radio return to receive mode once the CW text message has run?
I do not observe this behavior when I assert the Function key commands in N1MM+. Don't the Function keys assert PTT when used, too?
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
