N1MM+ SEND CW WINDOW HANGS FLEX 6300 IN XMT AFTER TEXT COMPLETES
Martin Blustine
Martin Blustine Member ✭✭
edited October 2023 in Contesting
When I use the N1MM+ CW Window, the Flex hangs in transmit mode with transmit bias enabled until I hit the ESC key, or CNTRL K once again.
Why does PTT remain enabled once the text has completed?
Is there a way around this? Why doesn't the radio return to receive mode once the CW text message has run?
I do not observe this behavior when I assert the Function key commands in N1MM+. Don't the Function keys assert PTT when used, too?
  • KH6XX
    KH6XX Member ✭✭
    What was the solution?
  • KH6XX
    KH6XX Member ✭✭
    I inadvertently had PTT checked in N1MM configuration for PTT via Radio Command CW Mode to ON and should be OFF. When I first do CTRL K to enter text, I notice the MOX is highlighted and remains highlighted and the radio will not return to receive mode automatically unless MOX is depressed. With the text window still open, at the end of subsequent text messages the MOX does not remain highlighted after the text is sent and receiver comes back normal. Need to now figure out how to eliminate the MOX from remaining highlighted on the initial message. Anyone any ideas? Thanks
