SmartLink from iOS still unavailable
Hi,
I am patient and keeping my fingers crossed that the Flex Team will solve it for us all.
I am in IT and really know what this means.
From Windows everything seems to be fine even there is a noticeable delay in connection.
From my iPad I still have no connection. In between 11 September and today I was only able yesterday to connect briefly from my iPad then it went dead.
Is this also analyzed and addressed?
Or it is just me and for everybody else with IOS out there works?
I have updated since first day my 6400 and 6500 to v3.5.9 with no issues so far.
Thank you Flex for your hard work!
73 de DM1TX
I dropped my Windows SmartLink connection and again have "No radio internet".
The Mac version also can not connect though it is showing as available.
Not sure if this is a one off --- but I noticed on my iPhone I could not connect remotely but after doing a shutdown and restart of the iPhone, it connected.
I can now connect with Mac also.
Smartlink appears to still be unstable... sometimes you can connected and other times not.
I have no connection via smartlink on my Iphone or Ipad - been this way for several days now. My local network works fine.
Hope this gets fixed soon!
Hi Bill, what version are you running? You need to be on 2.10.1 or 3.5.9 for SmartLink to work.
3.5.9 on my computers
Bill
My iPhone SmartSDR is working just fine using SmartLink.
OK, you have the latest 3.5.9 firmware for your Flex Radio.
Check the iPhone application store and make sure you have the latest version of SmartSDR. The new version will install, and the first time you run it, it will ask to download an updated security certificate file.
If you still cannot connect, then perhaps your Flex SmartLink is not working. Using a desktop SmartSDR, go to the SmartLink setup page and run the "Test". You should get a green light.
At this point, if you cannot connect your iPhone SmartSDR using SmartLink, time to submit a help request ticket to Flex. Be sure to tell them all the steps you have taken so far.
Alan. WA9WUD
Thank you all for answering. It seems that it is stable now and I can use again my ipad and iphone to connect.
However I am looking into alternative solution using a VPN.
- 391 Community Topics
- 664 The Flea Market
- 157 SmartSDR+
- 441 SmartSDR for Mac
- 275 SmartSDR for iOS
- 265 SmartSDR CAT
- 206 DAX
- 386 SmartSDR API
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 144 Amateur Radio Interests
