Ongoing SmartLink issue?
I'm aware of the recent SmartLink outage and have read all the posts from FlexRadio and the Flexers. I can now log on to SmartLink, but it "refuses my command" when I hardware key my 6400 in an attempt to register. Any suggestions, other than continuing to try? I don't have to be hooked up to the LAN where my radio was originally registered, do I?
  • Ha Gei
    Ha Gei Member ✭✭✭
    Answer ✓
    Your radio should not need to re-register at all..
    Once registered, it is reeachable.
    When you say "the lan where" are you sure you have set up portforwarding correctly and your provider supports IPV4 or mixed mode.
    Currently smartlink works flawless here. Inside or from outside my network.
    Harry
    Dl9NDW
