No Audio to my 6300 since 2.10.1 Upgrade
I have seen a couple other posts but not exactly the issue I am seeing. I upgraded from 2.9.x to 2.10.1 on Friday (2 days ago). The Flex is located in the house but not the shack, connected through a router by Cat6 cable. All was well before the upgrade. I run a lot of WSJT-X. After the upgrade I went band by band on the 6300 and tuned up so as to get the Autotuner set since everything had been powered off and restarted. That worked ok. I then went to WSJT-X and tried to operate. Could not work anyone. Hit TUNE in WSJT-X (PWR set to max) and looked at SmartSDR. Barely a flicker of Power Out. Only change that was made was the SmartSDR upgrade. Saw the post about SDSR when computer goes to sleep. That is not the case with my desktop. It seems to get a lvery low level audio signal, just enough to get the bar graph to respond. I tried with a reboot, checked the settings in WSJT-X, etc. Anyone seen this. Maybe I am doing something ****.
Thanks for the suggestion. 2.10.1 indeed deleted my profile and It appeared in the dropdown but really did not exist. Still no decode but I think it may still be profile related.
Thanks for reading.
- 694 The Flea Market
