Radio.CWSpeed is vexing me using FlexLib.dll
Keith Regli (K7KAR)
in SmartSDR API
I'm using Visual Studio and referencing FlexLib.dll (and the others).
I init and connect to the radio (6600M) via calls to the dll. I then have a Radio called ActiveRadio. I then execute the following code:
ActiveRadio.CWSpeed = 10;
Console.WriteLine(ActiveRadio.CWSpeed.ToString());
ActiveRadio.GetCWX().Send("x");
Thread.Sleep(1000);
The output from the two console writes is:
10
30
You can replace the send by hitting the paddle with the same result. If I remove the Sleep the output is:
10
10
Am I missing something or is the dll giving me misleading info? The speed actually does stay at 10. If I reduce the sleep to less than 40 I get 10 10 as the output.
- 692 The Flea Market
