Antenna Connectors
Davidn
Davidn Member ✭✭
Are the antenna connectors not being used open, closed switched to ground?
With a power failure do the switched positions stay the same?
    Answer ✓
    Hi David, the unused connectors are grounded.
    Hi David, what equipment are you referencing?
  • Davidn
    Davidn Member ✭✭
    Genius 8 X 2
    I don't know what happens when it loses power or if you shut it off. I guess you could just give it a try and see what happens.
