QSK using Tuner Genius and 6600 ...
W7NGA
W7NGA Member ✭✭✭
I am going to assume that with the switching constraints at the tuner that QSK operation with a 6600 is not workable. Or, once you find a tuning solution can you lock the tuner (no receive bypass) so that no switching is required and QSK is doable. Or, is there always some form of switching that must occur at the tuner?
W7NGA
