How can I resolve 6300 transverter transmit problem?
I am new to Flex with recently acquired 6300. Radio installed on home network with excellent connection and running SCR v3.2.39. Everything seems to be working as expected, except transverter port. Ukraine 2 meter transverter displays spectrum and hears signals from 144 to 148 MHz. The radio and transverter are keyed but no 28 MHz RF is produced to drive the transverter. When frequency is set above ~145.7 MHz, MOX says "Out of Band." The transverter transmits and receives when connected to Ant1 with radio operating on 10 meter band at 1-2 Watts. I have reviewed manuals, talked with friends, watched videos, and checked community posts. Any suggestions? Thanks...Bill (KB1WEA)
  • SebecRadio
    SebecRadio Member ✭
    Answer ✓
    I finally found the problem. Me. Watching a Flex video on transverter setup. the TX PWR column in the TX Settings table was mentioned, "power in percent not Watts." When I corrected my mistake, transverter is now working fine. Thanks, Bill
    Hi Bill, can you post a screen shot of your XVTR tab of your Radio Setup screen?
    Here is how I have my 6400 set up to use my Ukranian transverter:
  • SebecRadio
    SebecRadio Member ✭
    Thanks, Len...any ideas? ...Bill
    Hi Bill, that 15 dBm Max Power looks suspicious. I think that the transverter function in the Flex is only capable of up to +10 dBm. Change that down to something 10 or lower (5.5 gives me 10 W out on mine). If it still does not work, I would submit a help desk ticket.
  • SebecRadio
    SebecRadio Member ✭
    Len, various power settings did not make any difference. The transverter has an in line attenuator allowing for up to 5 Watts input...Bill
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    edited August 2023
    Can you bypass the attenuator? That's about 30dB (10dBm is 10mW) so I think that is the problem.
    Yep, I think Geoff is right. I don't have the version with the attenuator, but I think it is straightforward to take it out of the circuit. I don't know if it needs to be unsoldered or if there are connectors, but a quick peek in the case should tell you what to do.
  • SebecRadio
    SebecRadio Member ✭
    Thanks Len and Geoff...There is no RF output from the transverter's BNC connector. Using another transverter without attenuator did not work. There is either some obscure software setting inhibiting output or a component failure...Bill
    Hi Bill, I would submit a help desk ticket.
  • SebecRadio
    SebecRadio Member ✭
    Thanks Len...
