Flex 5000A i need help to connect two wire on Molex rf connector
after going through a bad experience that I don't want to go into explaining.
I'm asking for help figuring out where to connect the two small cables behind the antenna panel of my Flex5000A.
two black cables, one of which is marked in white. two empty Molex plugs on the antenna board PCB XURX IN and XURX IF. What is the correct connection of the black and white cable?
  • IK8HCG
    IK8HCG Member ✭✭
    all solved
    black with white label goes to RX1 IN, Black wire XUTX J15
