Flex upgrade 3.5.8 New CAT error
Mick  W8BE
Mick W8BE ✭✭✭
edited August 2023 in SmartSDR for Windows
Hi, Just upgraded to 3.5.8. Now I am seeing the CAT error below when I shut down the program. Cat seems to work fine and this only occurs on shut down. This is the first time I have seen this error.
Regards
Here is my system info...
PowerShell 7.3.6
PS C:\Users\w8beu> systeminfo
Host Name:         W8BE
OS Name:          Microsoft Windows 11 Pro
OS Version:        10.0.22631 N/A Build 22631
OS Manufacturer:      Microsoft Corporation
OS Configuration:     Standalone Workstation
OS Build Type:       Multiprocessor Free
Registered Owner:
Registered Organization:
Product ID:
Original Install Date:   5/11/22, 1:59:08 PM
System Boot Time:     8/9/23, 7:06:00 AM
System Manufacturer:    Gigabyte Technology Co., Ltd.
System Model:       Z390 AORUS PRO WIFI
System Type:        x64-based PC
Processor(s):       1 Processor(s) Installed.
              [01]: Intel64 Family 6 Model 158 Stepping 13 GenuineIntel ~3600 Mhz
BIOS Version:       American Megatrends Inc. F10, 6/5/19
Windows Directory:     C:\WINDOWS
System Directory:     C:\WINDOWS\system32
Boot Device:        \Device\HarddiskVolume13
System Locale:       en-us;English (United States)
Input Locale:       en-us;English (United States)
Time Zone:         (UTC-05:00) Eastern Time (US & Canada)
Total Physical Memory:   32,703 MB
Available Physical Memory: 25,728 MB
Virtual Memory: Max Size: 37,567 MB
Virtual Memory: Available: 27,040 MB
Virtual Memory: In Use:  10,527 MB
Page File Location(s):   C:\pagefile.sys
Domain:          WORKGROUP
Logon Server:       \\W8BE
Hotfix(s):         9 Hotfix(s) Installed.
              [01]: KB5028948
              [02]: KB5007297
              [03]: KB5012170
              [04]: KB5015669
              [05]: KB5018863
              [06]: KB5023595
              [07]: KB5027397
              [08]: KB5029359
              [09]: KB5029361
Network Card(s):      2 NIC(s) Installed.
              [01]: Intel(R) Wireless-AC 9560 160MHz
                 Connection Name: Wi-Fi
                 Status:     Hardware not present
              [02]: Intel(R) Ethernet Connection (7) I219-V
                 Connection Name: Eth0
                 DHCP Enabled:  Yes
                 DHCP Server:   192.168.0.1
                 IP address(es)
                 [01]: 192.168.0.xx
Hyper-V Requirements:   A hypervisor has been detected. Features required for Hyper-V will not be displayed.
  • Mick  W8BE
    I figured out the issue. It seems that 3.5.8 was throwing the error for my PTT on COM3. I did not have the foot switch connected and this is why I was getting a null error. I connected the foot switch and then deleted the com port and now when CAT is working normally. However this has been introduced in 3.5.8. I have never been required to keep a connected usb port connected to the CAT program. I would speculate that the developers missed handling null values in the new code.
  • Mick  W8BE
    I opened a ticket with Flex and they advised this is not a bug as I was using a com port to send cat commands to SmartSDR. The issue of the program throwing an exception error due to a null device in my opinion is valid. If this was normal behavior this should have been occurring before 3.5.8. Exception handling is a normal coding issue that needs to be accounted for by the developers.
  • WX7Y
    WX7Y ✭✭✭✭
    I lost about half of my MANY CAT ports from the Upgrade to 3.5.8 so check your SmartCat and make sure all the CAT Ports your Software uses are still there.
    I always copy my CAT settings file when I make a change over to a different location so I can easily restore thing when they Break which they have done over the last 10 years a time or two.
