6400 MD100 and Flex adapter cable
Pat Hamp
Strange but true. Probably an old person problem but. I key the mic but no audio. Also on the MD100 if I set the mic button to on, the system keys where with my 6300 I would need to push the PTT on the mic base. I also swapped back to the factory hand mic and again, keys but no audio. It was working now something has gone awry. I have looked at several posts about this but none of the fixes seem to work. I'm going to try a hard reset in the meantime just in case dummy here messed with something by accident.
Pat
Okay update. After two resets, the FMH-3 works as it should. It appears either the adapter or the mic cable from the MD100 Yaesu is the problem. Or the Flex adapter cable is not compatible. At least I'm operable now.
- 692 The Flea Market
- 119 Aurora
