What is causing extraneous noise on Flex-1500 transmit?
ysojim
Member, Unconfirmed ✭
See RF output scope shot at bottom of my QRZ page. Crunching noise happens only on first dit when T/R switch is activated. All subsequent elements are clean until receiver has been back on after break-in delay. Noise also can be seen when you press MOX.
Does anyone have a suggestion as to the cause? Thanks and 73. Jim AJ8S
- 995 Maestro
