Dumb Questions - VHF Transverter for Flex 6400
Questions -
1. How do you achieve off-set frequencies to align with VHF repeaters? I assume you would use Flex' FDX in some fashion.
2. And with the off-set, is there a global way to set those, making it easier when tuning frequencies?
3. The $849 pricetag for the Q5 Signal 150w VHF unit seems a bit high. Worth it? Other units with a better value?
73 - Ray, KE0YXX
- Notice on slice B, set to FM, that I clicked on OPT to show the FM options. I set the offset to 0.6 (same as 600 KHz) and in this case, I set it to a minus offset. This repeater uses a 100 Hz subaudible tone, so I selected CTCSS TX and 100.0 Hz. Note that I have slice B set for TX. With this setup, I will transmit on 146.100 and receive on 146.700. Even with a 6400, I can simultaneously receive another frequency (146.52 simplex, in this case).
2. The easiest is to set up the repeaters in memory.
3. The Q5 transverters are a bit pricey, but are among the best available. Mine is a cheap one that works fine for me (weekly FM club nets, etc), but if you do a lot of 2 M work, it may well be worth the money to get the Q5. If I didn't already have an 80 W amp, I probably would have bought the Q5.
Like @rbenton01 I want to hit FM repeaters near my home-station, when I am remote.
Looking at the transverters, they all talk about 144MHz - 146MHz, seemingly aimed at EME, weak-signal (SSB, CW), but they lack information about FM, repeaters, and 146MHz - 148MHz.
An inquiry to HA1YA reveals that his transverters are fine for 144MHz - 148MHz. So that RF-out is good.
http://www.ha1ya.hu/htmkepek/me2t_protransverterspec.htm
But what about the input? They all call for 28MHz-30MHz as the I.F. which gives you only 2MHz of coverage (then they mix with a 116MHz local-oscillator in the transverter).
QUESTION: Can the FlexRadio 6400 "Transverter" port give me +10dBm TX from 28MHz - 32MHz? This "extended coverage" beyond operating on 10m would address my desire.
Thanks in advance!
(and thanks to @KD0RC for screenshots showing CTSS, offsets, memories and other FM-ish stuff 😀
Hi Gord, the simple answer is "Yes".
Your 6400 transverter port will transmit places that the regular antenna ports will not. This gives you full coverage of the 2 meter band if your transverter is up to it.
Hey Gord, I just looked at the nice specs of the HA1YA transverters. The products look great, but I don't see any prices listed there. What did it cost to get it shipped to BC? Have you tried it yet with your 6400?
I had to ask for pricing; I don't have it yet, as I'm "radio-$$$ challenged" at the moment 😯 and Christmas is right around the corner. I was quoted shipping (Can / US) at 55Euro via FedEx.
I'm attaching the .PDF, but the summary: around $1000 Euro for single-band. Pricey.
On the website, the specs look good (hopefully this link remains for later Googlers):
Wow... More expensive than Q5 by quite a bit. The 150 watt Q5 is around $800 USD. The 25 watt Q5 is only $500 USD.
I thought it might be a little pricey given the excellent specs, but I didn't think it would exceed the Q5!
I also would like to add my endorsement of Q5 equipment as they perform very well. Corey does an excellent job of supporting his products.
Bill AB7AA
KD0RC, thanks for the screen shot of your setup. I’m somewhat confused about something Split A shows a frequency of 146.520 while B shows 146.700 which is 180 khz but your text says 146.100 for A I’m assuming the text is correct. I’m using SmartSDR for MacOS and the setup is very similar I’m able to transmit on B but there’s no signal shown being transmitted. A is showing a signal but I am getting no audio. Suggestions?
73 Sprocket
Don't try to do it using split and two slices. When I get home, I will get into the detail of how it works. In the meantime, check out the Flex Repeater Spots utility, I think it will make it all pretty easy to use.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
