Flex 3000 not recognized by computer
I have a Flex 3000 running perfectly and recently bought another Flex 3000. I replaced the old radio for the new one and used the same computer and cables, but the computer does not see the new 3000. Once I put the old radio back in line, everything works as it should. The computer only shows the old radio serial number.
Do I have a problem with the new radio or is there something up with the serial number?
  • Kevin Lewis
    Kevin Lewis Member
    Upon further investigation, the green light near the back of the 3000 is not lit. Something wrong inside the 3000.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Thanks for letting us know, Kevin. It helps when others come across the same situation. Much appreciated.
