Power Genius XL v3.7.32 Firmware and Utility
Check your firewall/antivirus software. It may be blocking the amp from entering boot loader mode.
I just have the Windows 10 firewall/antivirus, no additional third party firewall/antivirus, and have no alerts about it.
Also I will read again the Release Notes as I don't recall reading about doing anything in particular with the firewall/antivirus software in order to install the firmware update...
The Power Genius Utility v3.7.23 it did downloaded and installed OK, no problem.
It is only the firmware update after.
Turn OFF (disable) firewall/antivirus and the same as with the firewall/antivirus ON (enable), no difference.
I had the same IP Address error message issue on my windows 10 Pro computer, so I downloaded the new firmware to my desktop and executed the file from there, which worked. Problem also occurred, on my second Flex station setup, so again executed file from desktop, which worked.
Dewey, I'm running Windows 10 (Home) and that is where I download and run the file from (from the Download folder, not the Desktop).
The utility installed OK and it is the firmware update the one with the error on my end.
I believe what I did was within the PGXL utility screen, to click on the setup icon (cog wheel) and then choose firmware recovery, which then requested the location of the firmware software on my pc.
Thanks Dewey, well it turn out that today out of the blue the PGXL Utility worked and firmware was updated. Firewall/Antivirus untouched and active as always.
- 696 The Flea Market
- 121 Aurora
