Unhandled Error from CAT
markcamos
I get two Unhandled Error messages when I start SmartSDR CAT:
SmartSDR CAT (v3.4.23.15544): An unhandled error has occurred. The invocation of the constructor on type 'CatWPF.MainWindow' that matches the specified binding constraints threw an exception.
Inner Exception: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
at
FabulaTech.VSPK.FTVSPKControl.FtVspkApiInit(LPFNVSPKEVENTS IpfnOnEvent, IntPtr Context)
at FabulaTech.VSPK.FTVSPKControl.ApiInint()
at CatWPF.VSP.FTVirtualSerialPortAPI,,ctor()
at CatWPF.MainWindow,,ctor()
How can this be resolved?
at
Best Answers
Hi Mark, I would submit a help desk ticket.
In case anyone else sees one of these, this is the solution that Tim suggested. It worked, I no longer get the two errors and CAT stays running. http://helpdesk.flexradio.com/hc/requests/585260
Just, FYI, in case others run into this, I fixed it with help of support using the procedure in this article: https://helpdesk.flexradio.com/hc/en-us/articles/205665325-How-to-Repair-the-FlexVSP-Virtual-Serial-Port-Driver0
OK - I did.0
- 996 Maestro
