Flex 6600 and Tuner Genius XL RF Sense
The tuner is designed to require a press of the tune button on the tuner or tuner app. When integrated with the Flex radio, it will initiate a tune cycle.
The current SmartSDR does not allow the tune button in SmartSDR to initiate a tune cycle of the Tuner Genius.
If you are using a 6600, you will no doubt be using it in conjunction with a PC. Have you considered setting up a key on your keyboard to press when you want to tune the TGXL instead of reaching over to press the tune button itself on the TGXL?
I have done exactly that on my set-up. I chose "F10" to make for a quick depression of the button to initiate tune cycle. I actually use Smart SDR for Mac, and there is the facility to action the keyboard to do all sorts of things. On SmartSDR (for Windows computers) I guess you will be able to do the same if you have FRStack downloaded???
Mike G4GWH
The TGXL is a semi-automatic tuner. It does a great job of finding tuning solutions and storing them when you hit the TUNE button on the tuner or the app. It does a great job of recalling tuning solutions for different bands and antennas. However, it will not initiate a tuning cycle on its own.
It took me a while to get used to that but now I see it has advantages. There is nothing like the pain of an auto-tuner deciding on its own that it doesn't like the current SWR and doing a tuning cycle while you are in QSO and running an amp.
The SmartSDR TUNE button allows you to see the current SWR without bothering the tuner. The TUNE button on the tuner doesn't look at the current SWR but instead goes through a new tune cycle from scratch. To avoid that, first check your SWR using the TUNE button in SmartSDR and only if needed use the TUNE button on the tuner/app to find a better solution.
K1ESE
- 692 The Flea Market
- 119 Aurora
