Noise cancellation using 3rd-party software
Flex have been promising phase noise cancellation for a long time.
In the meantime, is it possible to do basic noise cancellation through 3rd-party software? I have a 6600 with a “noise” antenna on RX-A. So if my main receiver is on ANT1-Slice A (DAX Audio RX1) and RX-A is on Slice B (DAX Audio RX2), would it be possible to use Virtual Audio Cable or some other application to subtract one from the other and produce a “noise-cancelled” audio stream?
73 Graham VK3GA
You could try NoiseLsser Noise Reduction software PA0SIM
I quickly gave up on it. My experience with my 6400 is that a better solution is not 3rd party s/w but a 3rd party noise cancelling unit. I have the X-Phase one by RA0SMS. However, results probably depend on type of noise, source and strength. The s/w certainly did not help with 80m noise due to a local electric pylon transformer whereas the X-Phase killed it stone dead.
You could potentially cancel noise with an audio level solution, but you wouldn’t be able to prevent its effect on AGC. You are better off purchasing one of the several available outboard phase noise cancelers. Save that expensive SCU for use as a second receiver.
I am not aware of a separate software based noise phase canceller. But, there may be. I know in the SDRPlay RSPDuo RX, they have it built into the SDRUno software. And of course Anan 7000 DLE has it and others. The alternative is a hardware based approach using either of these two units:
MFJ Noise Canceling Signal Enhancers MFJ-1026
WiMo QRM Eliminator 26000
But, the hardware approach you won't be taking advantage of the SCUs inside the 6600.
Dan WA1QZX
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
