FLDigi Contesting Question
I'm relatively new to contesting. I'm currently working the BARTG RTTY Contest with my F6700 with FLDigi. I'm have a great time but I ran into an operational issue that is slowing me down. I have my F6700 set up to monitor 5 contest bands. In order to have the selected waterfall band information displayed on FLDigi I've been switching the DAX Channel 1 on the band slice I want to use (jumping between slices A thru E). This works fine except for FLDigi frequency display always indicates the Slice A frequency, so unless I've selected Slice A, when I select any of the other 4 slices of course this provides the incorrect frequency information to FLDigi and ACLOG. So currently my alternative has been to keep swapping Bands on Slice A, basically playing music chairs with the other 4 band slices so I'm always seeing all 5 contest band slices, and the band I'm working I put on Slice A.
I know I can run multiple instances of FLDigi and map them to different Slices but to minimize screen real estate I prefer to have only one instance of FLDigi running.
Ideally what I'd like to be able to do is, select between the 5 band slices and have that selected Slice activate DAX 1 and also change the selected slice to the Slice A indication, so FLDigi will read the correct frequency. Is this possible? Or might there be a work around using features of after-market programs such as Slice Master or FRStack?
Butch, KF4HR
- 692 The Flea Market
