I bought a used DEMI 144-28 25Watt transverter, seems to be functioning ok on the bench.
KE4DZU
This is an older unit with relay switching is anyone using these units for digital, specifically FT-8?
I have a pair Q5 Signal transverters (2m and 70cm) (same as DEMI) that I use just about every day for FT8. Both of mine are 25 watt versions and I use separate amplifiers with each one so I don't typically run the transverters are more than about 10watt output. They work great!
There should be no issue with it. I use the VHF, UHF on a 28Mhz IF and the 5 Bander on a 50Mhz IF daily.
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 837 Peripherals & Station Integration
- 146 Amateur Radio Interests
