Anyone having problems with v3.4.21 and xDax on MacOS?
I figured it was time to upgrade to 3.4.21 from 3.2.39. Upgrade went fine, SSDR for Mac and Windows work fine. However, xDax on the Mac no longer sees the slices on the “M” GUI! Tx slice appears, but no Rx, although DAX is enabled on the M front panel for channel 1 - no channel 1 on xDax :-(
Anyone else have issues with xDax with 3.4.21? Can anyone report it successfully working?
Thanks in advance for any input.
I guess I'll have to answer my own question here :-)
In the end, all I had to do was start xDax, switch the "Station" to the second Multiflex station (MacMini in my case), and then back to "Flex6600M" (my "M" GUI). It now worked. Only downside is you can't use xDax to connect to both the "M" front end and SSDR Mac at the same time - it's one ot the other :-(
By the way, Dave, if you need some help or guidance, just ask - there are a number of us Mac users here.
I just purchased my first MAC and can't even get it to start. xCAT seems okay. Not sure how to get any support so I looked here and saw your issue.
Dave N2OA
Same issue here Dave. xCAT works fine, but xDAX gives the error "xDAX closed unexpectedly". Can't get it to open either. I emailed the author, but did not get any response.
Charlie KB8CR
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
