Fill Palette Custom colors not taking
Trucker
Trucker Member ✭✭✭✭
V3.4.21
I just noticed when I try to do a custom fill color under the Advanced Tab in the pop out box for the Display in SmartSDR, that the custom color does not take when you select OK after making adjustments. I seem to recall that it would use the custom color in previous versions. Maybe there is an additional setting or button that needs to be pressed that I am overlooking?
  • Trucker
    Trucker Member ✭✭✭✭
    Answering my own question. Two things seem necessary for the selected color in the Advanced tab to work. The Fill Slider first needs to be all the way to the right. And second, the Weighted Average button needs to be off. Doing it that way, I can select a custom fill color for the panadapter. Kind of odd that it is that way.
