Issues with installing 3.3.33 on Win 11 Pro Insider Preview Build 25290-230128-1120
This is not critical - I was just trying to install latest version of SmartSDR on a new build of Windows 11 Pro Insider so I could play around with the API. Installer starts, goes through the questions and all ok - but then as you click INSTALL it just terminates with an error in event log.
I enabled /LOG on the command line for the installer and I have attached that too.
Here are some grabs and a GIF video of what happens.
Thoughts anyone? This is a 100% clean build, not an upgrade from 10 - on a clean SSD - nothing else installed - not even Visual Studio at this point.
Richard W4/G7EIX
Have you tried running the .exe under compatibility mode?
Some time ago this was a workaround for a lot of people trying to install it.
Worth a try.
Rich
Also, tried with 2.8.1. Same result, same errors.
Richard W4/G7EIX
Hi Richard, I would submit a help desk ticket.
I'll give it a day or two and try some options first. I may roll back the insider update and try again with the standard "retail" build before creating a ticket. If it installs with "retail" I will apply the Insider update afterwards to see if it breaks it - all in the name of testing for the sake of it! :-)
I see the installer has uncompressed some files into a temp folder before it crashes - so I am expecting this to be an issue with the installer and the latest build / security / quirk.
Richard
Rich M5RIC,
This worked. Don't know why I did not try that last night. It took a Brit to help a Brit! :-)
Cheers mate!
Richard W4/G7EIX
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
