JS8CALL No Dax Audio
chris1165
chris1165 Member ✭✭
edited February 2023 in Third-Party Software
I'm wondering if anyone else has experienced this problem. I have no problem with WSJT-X, JTDX or any other digital programs. However, I cannot get JS8CALL to work consistently or figure out why sometimes it works 20% of the time.
I can control SmartSDR with CAT using JS8Call with no issues. The audio doesn't always come through. When it stops working, below is what I see on the waterfall.
I've tried rebooting the 6400, restarting the computer, changing TCP ports, etc. Then for no reason, or reasons I can't figure out why, it will work until the next day when I try it again.
Any suggestions?
-Chris, N3MLB
  • chris1165
    chris1165 Member ✭✭
    It seems I spoke too soon. I found the fix and there is an error with JS8Call. The Array is not correct when it populates the list of INPUTS. If I pick RX2 from the list for Slice B(2), it doesn't work. The next on the list is RX7. If i pick that, the audio works.
    I tested this theory but changing everything to Slice A (RX1). RX1 wouldn't work but the next on the list is MIC AUDIO. I select MIC audio, and it works.
    I'll contact the developer.
    73 de Chris, N3MLB
