TX delay
n8et
n8et Member ✭
edited February 2023 in Third-Party Software
When I am using Fldigi or WSJTX it takes 4-5 seconds after I hit the tune button to see RF on the 6400, and the another 4-5 seconds to stop after I hit the tune button again?? It's like there is a TX Delay in the 6400....
  • Erik Carling EI4KF
    More like a delay in commanding the computer with the tune button and that command reaching the radio. On what OS, on what computer spec, and on what network dropout rate? One or more of these is not optimal rather than anything to do with the radio itself, I would say.
  • n8et
    n8et Member ✭
    That is most likely the reason. I noticed later that on Fldigi when I sent a CQ, it happened almost immediately. I'm running Windows 10 on an HP i5 computer.
  • Karl
    Karl Member ✭✭
    I was having the same issue and started to use SliceMaster to act as the go between.. Since installing SliceMaster i've had no issues at all.
    Karl
