6600M "Microsoft Sharepoint is Restarting"
This message is going across the 6600M screen every 10 minutes or so. Haven't seen this before. Anybody know what's happening?
Thanks,
Doug
I haven't either. I would create a support ticket.
This is not an issue with SmartSDR or the FlexRadio.
It is a Windows Operating system issue.
A brief google search revealed this response in one of the Windows forums:
(Google is your friend!)
"Based on the description you provide, the popup must be coming from OneDrive.
Refer some related links
This may at least send you to the right support pages.
Ken,
This was happening on the 6600M screen, not my computer. A reboot cured the problem. I'll send a ticket if I see it again.
I was seeing that same thing on my 6600M display. Rebooted and it cleared for a bit. Then it came back after a while and went away. At the time I was running the 6600M and PGXL in a Link-Local state as they did not have access to a DHCP server. I kinda wrote it off to that. Although I had done this before and had not seen that same issue.
I thought it was coming from the Maestro. I think the Maestro runs A version of Windows.
73, John K0TG
