Unable to See Spots on SmartSDR Pan Adapter using FRStack/ Flex 6600M / SliceMaster / CW Skimmer
Just installed SliceMaster and CW Skimmer. I can see the cluster spots from ve7cc on the pan adapter but no internally generated spots are showing. On the CW Skimmer call windows for A and B, I am seeing the calls. I am not seeing any internally generated spots on the pan adapters. On SliceMaster 6000 [v0.10.8a] I have Show Internal Spots and Send calls to N1MM logger+ enabled. For Spot Sources I have telnet://ve7cc.net and 192.168.140:7300 enabled, I already tried the default PC IP address and it makes no difference. Under Telnet I have Enabled aggregator server with Telnet Port 7300. CW Skimmer, GRITTY,WSJT-X, N1MM Logger + broadcasts all enabled. In SmartSDR>Settings>Spots I have Spots enabled.
All seems to be working with CW Skimmer except my local spots are not showing on the pan adapter. They do show in the A and B windows of CW Skinner. When I click on a call, it puts it correctly into N1MM. I suspect I have a port not correctly configured with the Spot Source for my PC or am I missing something in FRStack? As for SmartSDR, I am running v3.3.33 and have Slice A set to DAX Channel 1 and DAXIQ set to Channel 1. I have Slice B set to DAX Channel 2 and DAXIQ set to Channel 2.
Once I can get the internal spots working, I will then look at installing DXlabs.
Any help is appreciated.
Thanks,
Randy
KH6XX
  • rsobol
    rsobol Member ✭✭
    Forgot to mention, the spots for WSJT-X are showing on the pan adapter.
