i want to run my 6400 directly from the internet not wi-fi . i have a modem and router which do i co
DonE
Don,
Your cable modem must connect only to your router. Then, your computer and the 6400 will plug into Ethernet ports on the router. Most routers only have 4 or so ports, often not nearly enough for a modern ham shack. To expand the available ports, you can buy inexpensive Ethernet switches from Amazon or other sources. They are available in 5, 8, 16 and even more ports. An "un-managed" switch will be fine.
73, Craig KØCF
Thanks Craig that is the way i have it just was not sure
- 690 The Flea Market
- 461 SmartSDR for Mac
- 112 Aurora
- 976 Genius Products
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
