Help with using SSB Voice Caller Software and the 6400
What I have determined so far is that DAX must be enabled in order for the Voice Caller in N3FJP to work, and it does work. It also seems that I am not able to transmit on the USB headset microphone while DAX is enabled. This means that in order to effectively use the voice caller I need to flip on DAX, activate the voice call, then flip DAX back off in order to use the microphone again.
Is there a workaround for this? It sure would be nice if MOX would just override the DAX setting when used. Is there a way to send the USB headset microphone audio directly to DAX?
I am not sure if N3FJP sends the correct CAT commands to turn DAX on and off as required. N1MM does it correctly if you want to give it a try.
Check with the author of N3FJP to send the radio the following commands to the radio.
The key command is ZZDX1; and ZZDX0; (on and off)
2021-01-22 09:03:05.952 COM4 [sent]: ZZTX1; << Radio to TX 2021-01-22 09:03:05.982 COM4 [sent]: ZZDX; << query DX setting 2021-01-22 09:03:05.983 COM4 [rcvd]: ZZDX0; << answer DAX TX is off 2021-01-22 09:03:05.988 COM4 [sent]: ZZDX1; << turn on DAX TX 2021-01-22 09:03:06.066 COM4 [sent]: ZZMG; << ask Mic gain 2021-01-22 09:03:06.068 COM4 [rcvd]: ZZMG066; << set to 66 2021-01-22 09:03:06.072 COM4 [sent]: ZZMG000; << set gain to Zero message plays 2021-01-22 09:03:07.402 COM4 [sent]: ZZDX0; << set TX DAX Off 2021-01-22 09:03:07.408 COM4 [sent]: ZZMG066; << set Mic Gain to 66 2021-01-22 09:03:07.414 COM4 [sent]: ZZTX0; << move to RX
Thanks, this is very helpful. I’ll follow up.0
Discussions with N3FJP were not fruitful. They don't have a Flex radio to test with and are using the DLL. However, I have been able to create a multi-action button on my Streamdeck using Node Red that sandwiches the DAX on and off commands around the N3FJP voice caller command. I think that will suffice for what I am trying to do.0
K9DUR "Voice Keyer" Software https://k9dur.us/voice_keyer.php works very well and is easy to setup and use.
It is a standalone program with out any extra stuff to setup or you may not need.
Bret
WX7Y
I would go back to them and tell them to treat it like a Kenwood radio and just insert the same commands I provided. If they need access to a remote radio for testing, we can make that happen. They just have email devhelp@flexradio.com
I'm pretty sure that has been passed on before. The N1MM guys seem to have it functional.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
