minimum voltage for operation
rock
Member, Unconfirmed ✭
I know most 100 watt amateur radios are designed to run on 13.8 volts, what is the minimum voltage the flex 6600 can run on before encountering any problems
I have the 6000 power specs on my web page along with some notes about adjusting my Astron power supply. I ran into some low voltage problems with my 6700 years ago and have been running 15V since then on both my 6700 and 6600.
http://www.nn4zz.com/Flex6600.htm#Astron_Power_Supply
Here is a more detailed look at my original 6700 voltage lockup problem and how I solved it.
http://www.nn4zz.com/Flex6700.htm#Low_Voltage_Lockup
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6600 Win10 Pro V2004 -- SSDR V3.3.33
- 696 The Flea Market
- 121 Aurora
- 983 Genius Products
