FR-6600& PA conection
Hello!
Im owner an FR6600 and have encountered problems connecting two different amplifiers. I use OM-4001 for Slice A and SPE 1.3K-FA for Slice B. Both amplifiers are connected to the FR with USB cables, so I have no problem with the CAT control.
But the problem occurs when I go from Slice A to Slice B and the OM4001A follows suit. It automatically detects the frequency on Slice B and tunes in there. The same thing happens with SPE1,3 when I go from Slice B to Slice A. It doesn't transmit because I have it defined with TX1 and TX2, but what bothers me is that both amplifiers tune into the slice that is active at the time .
Does anyone have any experience with this problem and if it is even possible to solve it.
Of course, each slice is set to the respective SO2R TX1 profile and the other to the SO2R TX2.
Thanks for the advance replies.
73 Dare S58M
  • Jeff Schwartz
    Jeff Schwartz Member ✭✭
    Answer ✓
    I’m the USB Cables menu set one amp to respond to only Slice A and the other to Slice B in the Source box.
