FLEX-6600 Mac mini Panadaptor is blank??
Updated fw to the latest and now the panadaptor is blank. No slice control on the paradaptor window. Anyone experience this?
Usually run with wsjtx with the Loopback tool, with DAX streaming on no audio between radio and wsjtx.
I have reset several times with no luck.
Any ideas?
  • va3fmn
    Having same issue
    Hi
    I am on a 6300 with iMac, when I updated the flex firmware to 3.4.23 I lose my pan adapter waterfall etc. Just a grey screen.
    If I go backwards to firmware 3.2.39.it works again.
    Is this something you can advise? Is SmartSDR 2.4.7 and the firmware compatible with my flex-6300?
    I have the following issue/feature request for the app SmartSDR for Mac-macOS--1 V2.4.7, D4.1.5 fw:3.4.23 running on x86_64 on macOS Version 12.6.3 (Build 21G419)
    Allan
    VA3-FMN
