Having trouble consistently keying radio remotely on latest SmartSDR for Windows
I've searched the forum quickly for similar problems, but without much luck.
I've pursuaded my local club to purchase a used 6400M. It's been supplied by another member who has a lot of knowledge with Flex and with both MacOS and iOS Flex client software, but not with Windows.
The radio is set up in our clubhouse, and we will mainly access it remotely.
Three club members are currently testing the radio. The radio supplier, myself, and another member.
The supplier is having no problems, using Apple products. Myself and the other member are having an issue. We are both using Windows 10 (fully updated), and are both having the same problem independantly. Both of us are relatively tech-savvy, but after two weeks of head-scratching we have hit a brick wall and need some help.
Regardless of any settings we seem to choose, audio profile, TX profile or anything else, intermittantly, when we hit the MOX button, we see our audio represented correctly on the input audio level meter in SmartSDR, but no SSB carrier is transmitted. When we try it five minutes later, everything is fine, and so it goes on. It's almost like TX has been temporarily inhibited.
We have an 80/40/20/15/10m EFHW antenna on Ant1 and a 100W dummy load on Ant2 available.
If, when it is working, I turn the RF power down to 0, I see exactly the same response.
I also have access to another club's Flex 6600, and I experience the same problem there!
I'm so confused now, I really need some advice.
Thanks for reading, and sorry for the insanely long first post.
Berni M0XYF
Hi Berni, when you have the issue, is there another user logged in to the radio? I ask because the radio only has one transmitter. If the other user is transmitting, you will be locked out until they go back to receive.
Another thing to consider is if you and another user are both using the same profiles. I believe that can cause issues too. If this is the case, create a set of profiles for each user and see if that fixes the issue.
If you are alone on the machine and have this issue, then I would submit a helpdesk ticket.
OK, thanks for that Len. The former is definitely not the case, but the latter may be true - i.e. one of 'common' profile use, so we will gladly now go and specifically test that scenario and report back.
Berni M0XYF0
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
