How to get Flamp to work on two open slices?
W8PAB
Member ✭
I have Fldigi setup to run on both slices. All seems to work well except Flamp. If the first message received comes in on Slice B then Flamp will not work on Slice A. The same is true if the first message comes in onSlice A then Flamp will not work on Slice B. I would think that both slices should be able to receive messages on Flamp at the same time. Any suggestions? Must bre a setup problem.
- 322 Shack Infrastructure
- 227 Networking
