FT-991a and Power Genius CAT connection
Good Morning/Evening.
I'm using a straight through cable in an attempt to use my 991a with my PGXL as well as the flex.
https://www.amazon.com/dp/B07XP4NCMD?psc=1&ref=ppx_yo2ov_dt_b_product_details
I'm only seeing instructions in the manual for the ftdx5k and also dont see the 991 as selectable in the setup via PGXL utility. Is this radio compatible? I've tried the two different Yaesu selections, the FT1k and the other with multiple radios with no success, not even intermittent.
Perhaps is there a setting in the 991 that needs triggering? Cat rate is set accordingly, CAT is selected as communication via RS232. Its plugged into port B on the PGXL, the flex is in port A.
Feel like i'm missing something obvious! Not sure how to connect my TGXL to the 991 either, Y cable or something?
Update, my Tuner does communicate with the radio via CAT. Sort of....
Same settings with the PGXL, nothing.
The decimal is in the wrong place. Instead of 7.189 (40m) it shows 718.900. And my radio definitely isnt listed in the drop down, most arent.
Also, in the instructions there is a screenshot of a Yaesu setup with baud rate 4800 and 8N1 selected, I dont think those two work together? If not, probably going to cause some considerable confusion on end users.
Do I need another DIN to db9 for band data maybe? As in, two COM cables from the radio to the flex stuff?
- 690 The Flea Market
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
