Register new radio
I have just received my repaired 6400 back from Flex. I downloaded 3.22 , powered up the radio, green light flashed about 12 times then went solid green. Then opened up the software and it says no radio available and it does not have my name or call sign anymore. They said the radio has a new serial number and I would have to register the radio. How do I do that?
The instructions do not seem to match my menu. I log in and it shows my call sign and my flex 6400. The options are to connect, smartlink setup and low BW connection. Click on smartlink setup and it shows the radio model and a test button to show both radio and computer are on the local network, I get a green light. No option to register the radio. I just get cannot connect to radio.
Any further suggestions?
If the radio is on the local lan, smartlink won’t connect. Smartlink is only for remote, over the internet operation. To register a radio to smartlink requires an internet connection.
I mislead you, I received the radio yesterday from flex repair. I downloaded the latest software and installed it on my windows computer. Connected the flex radio to my computer via a 10/100 switch which is plugged into my internet modem. When I open SDR, the screen with my call sign radio serial number comes up and it says on the bottom left "connect". I press connect and a few seconds later it says radio not found.
I have opened a ticket with Flex and am awaiting an answer. Radio is six months old and they replaced the motherboard. There was a mention that I would have to register the radio as the new motherboard gave it a new radio designation. I need to access the radio to register it but cannot seem to do that.
contact flex using the original trouble ticket number ...
and
see if flex has updated their database with the radio serial number for version 3
remember purchased versions stay with the radio
and
find out what version ssdr they loaded on to the 6400 radio.
You need that same exact version on your PC for the PC to even see it. When you updated the PC you may no tbe out of synce with version between radio and PC.
Paul K3SF
- 688 The Flea Market
- 105 Aurora
