CAT Losing Ports
in SmartSDR CAT
I'm running SmartSDR CAT 3.3.32. I started up SmartSDR and WSJTx this morning and wasn't able to transmit. I check DAX and it was functioning correctly. After scratching my head a bit, I looked at CAT and discovered it had lost the PTT port. According to WSJTx Settings, it should have been serial port 12. I checked the Windows Device list and port 12 existed. When I tried to add PTT back using serial port 12, it wasn't available in the "Existing" drop down list. I had to create a new serial port (14) for PTT, then I could transmit. I deleted serial port 12 to avoid future confusion. Is it normal for SmartSDR CAT to lose it's marbles???
- 407 Community Topics
- 704 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
