Mounting an Antenna Genius to my Tower.
Looking at the Antenna Genius it seems there is no easy way of mounting the unit on a tower where the SO239 connectors would be facing down. Plus it also seems that the Antenna Genius is not very water proof like my DX Engineering 8 antenna switch. Am I correct in this assumption? Also, those of you who currently use the Antenna Genius how did you mount the unit on your tower? And I hate to say this, but a picture would be worth a thousand words. Thanks!
Mark Griffin, KB3Z
  • David Decoons, wo2x
    Mark, you can mount the AG in a weatherproof box such as a Hoffman enclosure.
  • Mark Griffin
    Mark Griffin Member ✭✭✭
    Dave,
    With my present setup even putting in the antenna genius into a utility enclosure box, it would be a lot more work then I really want to undertake. I think I am just going to continue to use my DX Engineering 8 port antenna tower switch like I always have.
    Mark KB3Z
